Water presure
发表于 2021-8-31 22:07:19 | 显示全部楼层 |阅读模式
I've Just finished my new tig machine and I would like to know how much water pressure the little hoses On the torch will work well at. For the present I am using my household water supply and it is about 70 lbs per square inch. so I bought  a water regulator. Usually I just go by trial and error but the new torch and hose I do not want to replace or repair.   Mac
Reply:Originally Posted by Tool MakerI've Just finished my new tig machine and I would like to know how much water pressure the little hoses On the torch will work well at. For the present I am using my household water supply and it is about 70 lbs per square inch. so I bought  a water regulator. Usually I just go by trial and error but the new torch and hose I do not want to replace or repair.   Mac
Reply:Thank You Foxhire. That is good working information. I should be able to work with that.   Mac
GMT+8, 2026-1-2 22:14 , Processed in 0.100476 second(s), 18 queries .
