My Magnum cooler needs a new fan
发表于 2021-8-31 22:07:15 | 显示全部楼层 |阅读模式
I noticed a squeek coming from my cooler and after taking it apart I discovered the fan had lost it's fit on the motor shaft.......The part number is M-16384-2  I bought it 16 years ago and have never had any problems till now.....I did notice the newer fans have a set screw in them (Mine doesn't) anyone know where I can get a set screw style that will work in my cooler?  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:I just replaced the fan and pump in my magnum after 16 years as well. the pump came from lincoln and the fan from grainger it cost about 45 bucks. I just matched info off of existing fan motor to grainger fan motor. hope this helps. J
Reply:OK thanks I'll check with them......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:If the hub of the fan has enough material, why not drill and tap for a set screw?Rex
Reply:Originally Posted by rode2rouenIf the hub of the fan has enough material, why not drill and tap for a set screw?Rex
GMT+8, 2026-1-2 23:48 , Processed in 0.115800 second(s), 18 queries .
