Lincoln AC-225 Amps
发表于 2021-8-31 22:07:14 | 显示全部楼层 |阅读模式
A year or so ago I purchased a used Lincoln.  The man had it plugged in and working but said he was using it on 30amps.  He kept the plug.  I put a 50A plug on it and added a 50A outlet for it at the main power box. Works like a charm.For logistical reasons, I'd like to use it on 30A if possible. The unit says "Input 50A".Anyone know for sure whether it will run on 30a?Many thanks,Jim
Reply:It will run on 30 amps and do smaller light to medium work but, if you get into something bigger on higher current settings, you can expect to trip the breaker. We used one of these on a 30 amp breaker and 250' of 10/3 ga wire to build a roof frame for a 7' square well house. The only power available there was 30 amps at 240 volts that was intended for running the well pump, and we re-purposed it temporarily.  Most of the construction involved welding 1 1/2 X 1/8 angle together and the little Lincoln did the job without even tripping the breaker. If that's all you have, then it's better than nothing. Just expect to trip the 30A breaker if you try to do anything on higher (> 125 amp) settings. The hotter the arc, the higher the current that you will need to power it.  It really should have a 50 amp power source.CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:Originally Posted by CharleyLIt will run on 30 amps and do smaller light to medium work but, if you get into something bigger on higher current settings, you can expect to trip the breaker. We used one of these on a 30 amp breaker and 250' of 10/3 ga wire to build a roof frame for a 7' square well house. The only power available there was 30 amps at 240 volts that was intended for running the well pump, and we re-purposed it temporarily.  Most of the construction involved welding 1 1/2 X 1/8 angle together and the little Lincoln did the job without even tripping the breaker. If that's all you have, then it's better than nothing. Just expect to trip the 30A breaker if you try to do anything on higher (> 125 amp) settings. The hotter the arc, the higher the current that you will need to power it.  It really should have a 50 amp power source.Charley
GMT+8, 2026-1-2 23:48 , Processed in 0.133391 second(s), 18 queries .
