Royal Purple oil in SA 200
发表于 2021-8-31 22:07:13 | 显示全部楼层 |阅读模式
Anyone use Royal Purple synthetic in their SA 200 ?  I m having a fresh engine dropped in and was contemplating a switch from conventional oil.
Reply:be sure to upgrade your filtration system to allow you to reap all the bennefits of syn-oil. otherwise not that great of an idea to me
Reply:Originally Posted by lincweldAnyone use Royal Purple synthetic in their SA 200 ?  I m having a fresh engine dropped in and was contemplating a switch from conventional oil.
Reply:I think it would be unnecessary. Your Continental will probably last 40-50 years with a regular change of good quality oil as it is. Why add an expense in a motor that stays at 3 RPM's it's whole life? (idle, high idle, and load)    Save that race oil for the hot rod that gobbles up the tachometer.
GMT+8, 2026-1-2 22:14 , Processed in 0.071248 second(s), 18 queries .
