Cast aluminum speaker cage repair
发表于 2021-8-31 22:07:09 | 显示全部楼层 |阅读模式
The owner dropped this and it broke to pieces - several cracks in the remaining large piece too.Speaker was $700 I'm told, and the manufacturer no longer makes the cage.1963 Airco 300 tig, 1/8" pure tungsten, #7 cup, 20cfh argon, 230 amps max on 1/4" sections.The coating was a super hard rubberized coating of some kind, took a wire wheel on angle grinder to get most of it - sand blast the rest - then die grind and cutter wheel to finish prep.Bottom welded out.All parts were V cut for welding after being tacked into position.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Coming out pretty decent All done - he said not to go crazy finish grinding The speaker that goes in it weighs a lot!Last edited by MinnesotaDave; 03-28-2015 at 11:44 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I like "pretty decent". I resemble "pretty decent".Nice save! I love it when they tell you it was expensive and they can no longer get a replacement. $$$ GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by GravelI like "pretty decent". I resemble "pretty decent".Nice save! I love it when they tell you it was expensive and they can no longer get a replacement. $$$
Reply:Originally Posted by MinnesotaDaveThanks  wish I could charge him a lot - but he has brought me work from his boss this year, delivered, picked up, and brought me the checks And this speaker belongs to his hired man for his own side shop business - gotta cut him a little slack
Reply:Damm very nice repair you performed. Good job that looks great.Pidge.Lincoln210mpHobart Handler 125...soldBoat battery and a couple coat hangers
Reply:That repair came out damn good, I also love that all your tig welding is done on a 1963 airco.Millermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina
Reply:Nice repair, glad to see you using a "vintage" machine. The HF on my 99 Syncro 250 just quit and I'm fighting the urge to go inverter.PeterEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:Nice save there Dave www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Way to go champ, save and a beauty! Looks great Dave!.......yes I called you champ, lol.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Nice repair indeed!Miller 180SDLincoln weld pak 180Hobart 250ciMill Lathe
Reply:Originally Posted by PidgeDamm very nice repair you performed. Good job that looks great.Pidge.
Reply:Do the money dance Dave You're a stud! Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Originally Posted by mnrjohnsonNice repair indeed!
Reply:Nice work Dave!Question, dropped it must've been from a fair height!Has he had it going yet, alignment tolerances will be a factor here as the voice coil must be perfectly centralised otherwise the magnetic field will be effected... its one of the main factors between cheap and high quality speaker drivers!
Reply:Great looking repair.....mabe the old cast stuff is better quality( actually can be welded) than the new mix of whatever they can melt down and make into stuff...Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Nice repair and save "slick". MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by Harry72Nice work Dave!Question, dropped it must've been from a fair height!Has he had it going yet, alignment tolerances will be a factor here as the voice coil must be perfectly centralised otherwise the magnetic field will be effected... its one of the main factors between cheap and high quality speaker drivers!
Reply:It might  not be a BOSS but I appreciate bench work as I age like wine! Nice one MNDave. I usually get stupid side jobs.
Reply:Originally Posted by mikecwikIt might  not be a BOSS but I appreciate bench work as I age like wine! Nice one MNDave. I usually get stupid side jobs.
GMT+8, 2026-1-2 22:15 , Processed in 0.099680 second(s), 18 queries .
