handle for smoker
发表于 2021-8-31 22:07:07 | 显示全部楼层 |阅读模式
Hey there....I am looking for ideas for a handle/closure for a door on a upright cabinet. Basically a handle that is attached to the door that will hook to a latch on the cabinet itself. Thanks in advance.
Reply:bent hunk of metal, wrenchspatulametal shaped like Antler, horns, claws, tusks, etc. basically the sky is the limit. have fun with it.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Buy a metal spring like thing from ebay. http://www.ebay.com/itm/5-INCH-STAIN...item3f4a19db8aMillermatic 200Miller Spectrum 2050
Reply:I've seen basket twists either home made or bought from some place like King metals used, or even something as simple as an old chipping hammer, similar to the spring shown. Wood dowel over steel is common as well..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Chain links welded together. Dan D.Manipulator Of Metal
Reply:good ideas.....but I guess i didn't explain myself better. I am talking about a handle that rotates on the door which latches to a tab to secure the cabinet door to the cabinet.
Reply:latch?
Reply:Buy a cheap chipping hammer at Harbor Freight or the flea market and use the spring handle.....that's what I did.
Reply:I think you're not understanding us. all the latch need to do is rotate up and down to engage/disengage a tab/hook on the door frame. It can be anything you drill a hole through and mount on the door. just weld an appropriately sized/cut section of angle iron onto the door frame to catch it.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
GMT+8, 2026-1-2 22:15 , Processed in 0.099418 second(s), 18 queries .
