Guys I have no ideal where to find a sheet of lead that is 8"plus wide by 36" plus long that don't don't cost an arm/leg.If I had a choice on thickness it would be around 1/64 or thicker.If you have a sheet laying around your shop or know where I could check please let me know.Tks----Can'tWeld
Reply:Originally Posted by Can'tWeldGuys I have no ideal where to find a sheet of lead that is 8"plus wide by 36" plus long that don't don't cost an arm/leg.If I had a choice on thickness it would be around 1/64 or thicker.If you have a sheet laying around your shop or know where I could check please let me know.Tks----Can'tWeld
Reply:We used to get it for lining walls of x-ray rooms. I may still have a partial piece that size, but it's probably 1/8" and I doubt it's worth shipping.A more economical option might just be to pour it yourself. If you can work with pieces and solder them together, a cookie sheet would work, the kind with the turned up edges. You'd need to get it level in both directions if you need an even thickness. The easiest way I know how would be to fill the pan with water. I'd lay out sand on a table and get it as close as possible with a good torpedo level. Then I'd pour in some water and see how close I really was. I'd suck out the water, Shop vac would probably get most of it up, the carefully blot up the rest before drying it with a hair dryer. Try not to disturb the pan while you do this. Note : DO NOT POUR MOLTEN LEAD INTO A PAN THAT"S EVEN SLIGHTLY DAMP! The water will flash to steam and throw molten lead every where..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Call local demolition companies. I used to get it all the time when demoing parts of hospitals, dentist offices and doctors offices. It is between the layers of sheetrock.Also call the larger scrap yards, that is where I took the stuff I removed.
Reply:You could probably get a small roll of lead roof flashing from a local harware store.
Reply:Try plumbing or roofing supply house. They use it on their roof drains.
Reply:Thanks guys,scrap yards,never thought about that---
Reply:Originally Posted by DSWWe used to get it for lining walls of x-ray rooms. I may still have a partial piece that size, but it's probably 1/8" and I doubt it's worth shipping.
Reply:Was that by chance the John Stroger Hospital? ...speaking of crooks
Reply:Lead lined drywall: probably about the best sound proofing material there is. Beats the "this Old House" idea of fiberglass in the walls by miles....No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Plumbing supply house for sure. Plumber= latin term. Means worker of lead. Also try a tile setter that does custom shower bases. There are tons of custom shower bases out there in lead. Around here that's Plumbers work. I'll check at work on Monday.
Reply:Originally Posted by DSWWe used to get it for lining walls of x-ray rooms. I may still have a partial piece that size, but it's probably 1/8" and I doubt it's worth shipping.A more economical option might just be to pour it yourself. If you can work with pieces and solder them together, a cookie sheet would work, the kind with the turned up edges. You'd need to get it level in both directions if you need an even thickness. The easiest way I know how would be to fill the pan with water. I'd lay out sand on a table and get it as close as possible with a good torpedo level. Then I'd pour in some water and see how close I really was. I'd suck out the water, Shop vac would probably get most of it up, the carefully blot up the rest before drying it with a hair dryer. Try not to disturb the pan while you do this. Note : DO NOT POUR MOLTEN LEAD INTO A PAN THAT"S EVEN SLIGHTLY DAMP! The water will flash to steam and throw molten lead every where.
Reply:I did a lead sheet on the floor of one of my cars, got it from a local roofing supply place. it wasn't ridiculously expensive from what I remember, might be an easy place for you to lookmiller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:Originally Posted by dunemetalWas that by chance the John Stroger Hospital? ...speaking of crooks |
