Tig Weld Newbie
发表于 2021-8-31 22:07:02 | 显示全部楼层 |阅读模式
Brand new to Tig welding. Started out running some beads on aluminum. I am having trouble with penetration to shallow vs blowout. Does this come with  seat time?Sent from my SM-N910V using Tapatalk
Reply:It takes time and observation to start understanding what happens and the remedies. If you have a foot pedal you can use it to your advantage. You also should practice feeding the wire through your fingers for an endless supply on a weld. Feeding the rod generously will take heat out of the puddle so in conjunction with pedal work you control the penetration and heat buildup. I basically never let the heat get ahead of me. Sometimes I preheat the piece.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Welcome to the forum.Lincoln A/C 225Everlast P/A 200
GMT+8, 2026-1-2 23:47 , Processed in 0.101474 second(s), 18 queries .
