Just ordered a lincoln 210mp
发表于 2021-8-31 22:07:01 | 显示全部楼层 |阅读模式
Well after me posted this and that craigslist add,  i decided to just buy a new 210mp  with a rebate  its $999.00    the bottle is $175,  but ill get that next month  i can try out the stick for now,   its coming thursday , i bought it from the local guy.   thanks for the help,  now i will be posting how to questions next!  lol....
Reply:You wont be desappointed.
Reply:You will like it. I liked mine. You can run the sample roll of flux core until you get your gasSteveLincoln SA200 (1966 Redface)Lincoln IdealArc 250Steve1990 Miller Dialarc 2501993 Miller Maxstar 140 STR2015 Lincoln MP2101966 Lincoln SA200 Redface
Reply:I just got mine yesterday.  I thought it wasn't such a good MIG welder because it sputtered way worse than the Hobart Handler 140  I was using.  Turns out the free role of wire included is .025, not .030 like I thought, so I set the machine up wrong.  Don't make that mistake.   Loaded up some Hobart .030 and it welds so good.  Now on to learning stick welding and TIG.
Reply:Another thing to watch is the flow meter. I was looking at the metric scale and wasted gas until l looked at it again and found the correct scale to useSteveLincoln SA200 (1966 Redface)Lincoln IdealArc 250Steve1990 Miller Dialarc 2501993 Miller Maxstar 140 STR2015 Lincoln MP2101966 Lincoln SA200 Redface
GMT+8, 2026-1-2 23:48 , Processed in 0.192012 second(s), 18 queries .
