I needed a light on my bandsaw. I had a flex light that came off the cheapo black and decker bench grinder I use to grind my tungsten. But the little turn switch was snapped off. Hmm. Now what to make it out of? Cant use anything that conducts electricity, unless I want the snot zapped out of me everytime I used it .......AH HA!!Junk screwdriver handle. Drill a tiny hole.Pretty close for a white boy.Works like a charm. If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Thumbs up. You can nearly buy a new light for the cost of a new switch.
Reply:Great little repair. I hate those turn switches... they break all the time. I'm sure they are made of the most brittle plastic possible or the heat gets to them. I bet your replacement will last longer than the brittle original provided it doesn't melt. I'll have to try your trick on the next one I break.
Reply:Nice job!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Good exemple of "Backyard engineering", you use what you got on hands and get the job done. Cost of that repair? 20 minutes of your time and the pleasure of sharing the result of your laber with others.*Well done! I drink to that.Miller MM211Esab Mini Arc 161LTSEsab Handy Plasma 380Duck tapeTy- rapKool-aid
Reply:Thanks guys The lathe is a century, cant remember the model, was made in 1982 I think. I can get some better pics monday.If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Now thats using your "handle"www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Nice job! A lathe can save you all kinds of problems and money if you have the time! I love fixing things using the lathe. |
