Trifitmet A81 plasma torch
发表于 2021-8-31 22:06:58 | 显示全部楼层 |阅读模式
anyone have any experience with this torch?  I just got one and it is arching between the work piece and the cup...melting the composite material on the cup.  Not impressed thus far...
Reply:Mine works fine I need the black composite peice for mine I half melted it!
Reply:I have one and it works great, but the black plastic on the outer nozzle that screws on is starting to melt away, right at the end that is closest to the arc.  It's cheap plastic I think.  Not able to withstand the heat.  Can't find any replacements on line.  Had to go to my local Fastenal and had them order a replacement from a Trafimet USA dealer.  The Trafimet dealer is Florida Power and Welding.  1-800-535-1185.  You need the Trafimet part number.  The part number for that piece is PC0115. You can't order directly from the dealer.  You have to go through a company like Fastenal.  If you call Florida Power and Welding, they will tell you what companies you can order through.  http://www.weldking.com/pdf/A81.pdf
Reply:Does anyone know what material the outer nozzle on a trafimet A81 torch is made up of?Last edited by Roland Steven; 02-13-2013 at 05:26 AM.
Reply:Another parts breakdown:  http://trafimetgroup.com/en/products...81-torch.html#"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I have the P-81 (machine torch) uses the same parts and have had no problems with it.  However it is on a CNC table and does not touch the metal when cutting.  You will find replacement parts on Ebay for both the short and long tips at a good price. Mine had a wiring problem it had the trigger switch wires both connected to the nozzel retaining cap ring this made the torch fire all the time when machine turned on. http://www.ebay.com/itm/170714156893...84.m1423.l2649
Reply:I don't know what the black material on the outer nozzle is made of, but it sure isn't heat proof.  That's the only thing about this unit so far that I don't like.  Considering the price I paid for it, I guess you get what you pay for LOL!     I found this to be the cheapest replacements that I've ordered.  Pretty fast shipping considering where they came from.http://www.ebay.com/itm/1pcs-Nozzle-...item2ebda986f2
GMT+8, 2026-1-2 23:48 , Processed in 0.122068 second(s), 18 queries .
