Where to buy a 25' extension for a WP26?
发表于 2021-8-31 22:06:57 | 显示全部楼层 |阅读模式
I have looked everywhere I can think of, Weldcraft does not even list an extension for a 26 series....anyone have any ideas?(this is a one piece hose/cable)ESAB Migmaster 250Ltec ST23 spoolgunMiller Passport
Reply:Build one.
Reply:buy longer argon line and use your stinger lead for power to the power blockno real need  to extend the torch power cable when you can just add lead and argon hose to get more reach from the machineI know you can get extensions for the water cooled torches tho but that's a different animalMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:CK  makes an extention for large gas through dinse connectors.
Reply:[QUOTE=WookieWelding;2278431]buy longer argon line and use your stinger lead for power to the power blockno real need  to extend the torch power cable when you can just add lead and argon hose to get more reach from the machineWe did this same thing with a watercooled torch. Longer water hoses, longer gas hose, welding cable connected to power block, went out to 100' on a portable rig. Make sure you insulate the power block and connection to it. Also adjusted pump pressure to compensate for length.
GMT+8, 2026-1-2 23:49 , Processed in 0.071053 second(s), 18 queries .
