Lincoln spool gun magnum sg 100
发表于 2021-8-31 22:06:55 | 显示全部楼层 |阅读模式
Does anyone know if I can use a magnum sg 100 spool gun on my Lincoln weld pak 3200...
Reply:Yes and no. Direct connect no. You will need the SG control module.You should be able to connect the trigger cable to the miggun trigger plug and the weld lead to the polarity stud. Then plug the control module into a 115 volt supply. Just make sure the control module is set for switch closure and not 115 volts out or you will fry your welder.See the control module's owners manual for how to set control module up.There are different control cables available depending on what type of weld you are conecting to.
GMT+8, 2026-1-3 01:23 , Processed in 0.071288 second(s), 18 queries .
