Broken wires
发表于 2021-8-31 22:06:54 | 显示全部楼层 |阅读模式
I have a Ranger 8 the output control selector became loose and when it was adjusted last it spun around and the wires came off the back I found the wiring schemadic and would like to see if I understood it right the wire numbered 77 wire would be on the left 76 would go on the middle and the 75 wire would go on the right if I were facing the control panel (I would like to know if I'm right before I soder the wires back on and reinstall the switch)
Reply:76 does go in the middle. Put 77 and 75 on the out side and then run before putting all the covers on. If it works backwards just reverse 77 and 75. won't damage anything.
Reply:You've got them correct Mike.BTW, welcome to the forum. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-2 23:57 , Processed in 0.104220 second(s), 18 queries .
