Any Merit Badge Counselors in the group?
发表于 2021-8-31 22:06:51 | 显示全部楼层 |阅读模式
My son has transitioned from Cub Scouts to Boy Scouts, and the troop is asking for parent involvement and gave "merit badge counselor" as a way to help. Anyone here a merit badge counselor, for welding or anything else? Curious to know how the Boy Scouts determine if you're qualified to be a counselor for the Welding merit badge, for instance.Thanks!
Reply:It's not very works, pretty much tell them.  I'm sure it's more strict that 30 years ago when I was in .Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:They have you fill out an application. Then you will be notified once a minimal background check clears. I am not a counselor anymore, but I think you have to renew every 1 or 2 years. Best call your local BSA council for more info.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I've got several families who are, or are working on becoming Eagle Scouts. I'll try to contact them for some info. You may have seen this info:http://bsaboston.doubleknot.com/volu...ounselor/30424http://www.aws.org/weldingbadge/TxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:Actually if you have even moderate welding skills the welding merit badge is not too onerous. Jody at weldingtipsandtricks.com has a number of videos on the subject. it seems the scout can do MIG or stick, and has to basically complete 4 tasks: draw initials on a plate with weld bead, complete a 3x3 inch pad of beads, do a lap joint in the horizontal and do a tee joint in the horizontal. You have to be able to provide safety gear for the scout(s) and give them instructions necessary to safely complete the 4 tasks. Weld joints don't need to be perfect. There are videos and resources at Lincoln Electric's website as well. The James F. Lincoln Foundation sells project kits that can be used as the coupons. The kits are like $5 each if you buy in bulk. You get 2 pieces of 1/4 inch plate, 3x3 inches, and 6 pieces of 1/8th inch plate 2x6 inches. The steel is cold rolled steel for the most part, so not much cleaning needed for either SMAW or MIGMiller Multimatic 255
Reply:I would think most any responsible person with reasonable technical skills and a bit of attention to detail would do fine on merit badge counseling.  Borrow one of their books on the badge requirements and read a bit.  Help a kid understand and complete the requirements.  I only made it to first class scout.  But I did get a couple merit badges like sharpening punji sticks and tossing cans of applesauce in the camp fire."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:here:  http://www.scouting.org/scoutsource/...s/welding.aspxMiller Multimatic 255
Reply:Got it- thanks for the info and links!
GMT+8, 2026-1-3 01:23 , Processed in 0.071774 second(s), 18 queries .
