My 3/8 with 110v machine experiment
发表于 2021-8-31 22:06:48 | 显示全部楼层 |阅读模式
Since David's thread covered fillet welds, i thought I might as well do a groove weld on 3/8 with my lincoln 135. For prep, i beveled two 3/8 plates and tacked them together with a 1/8 open root. No preheat. settings on the machine were tap D and 5.5+ on wire speed. (0.023 wire) Also on 30amp circut.This is the thrid pass out of fourHeres the back side of the weldCap it off, note that the dime gets very hot even after a shot timeThen I cut it into stripsAnd bend them, the one on the left broke, but that was the start of the weld so it was cold to start, lack of fusioncontinue on next post...CharlesThunderbolt AC/DCRed Flames BWELincoln sp-135t
Reply:Just a close up of the broken piece. thats where I tacked the plates together and didn't get enough penetration, you can clearly see this mistake on the pic of the backside of the weld, 2nd one down.CharlesThunderbolt AC/DCRed Flames BWELincoln sp-135t
Reply:Pretty nice, it shows that with proper preparation any thickness can be welded What gas did you used?My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Very nice Rich! I do a double bevel and I can root and final pass the material and it holds nicely. Thanks for going through the test.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:I used c-25 gasCharlesThunderbolt AC/DCRed Flames BWELincoln sp-135t
Reply:Nice job rich, Sorry I didn't get back to the chat room before you left, busy night at work. I thought those welds looked great and you showed a good example of welding 3/8 with a 110 welder.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Your welder has far more B*lls than mine.    Nice looking welds.  The best pic is the full penatration.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Geesh, now I will need to try this myself. My 110 miller mig welder is an old one like daves, so I think I will go and do some 3/8 plate to see how my welder compares. Again, awsome looking work Rich. For only being 17, I think you are going to excel in the welding field.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Tonight I'll try a fillet weld with similar jiont prep. and see what kind of results I can get.CharlesThunderbolt AC/DCRed Flames BWELincoln sp-135t
Reply:hey Charles.... nice demo.... I have some questions ...What position was this welded in? did you weld the backside of the root pass?_________________Chris
Reply:Nice.... may i ask you what size wire you were using? i am guessing 0.35?-Clarke 130EN-Miller MaxStar 150STL-Miller Elite 29' Roadster
Reply:Originally Posted by richcharles (0.023 wire)
Reply:Originally Posted by lorenzohey Charles.... nice demo.... I have some questions ...What position was this welded in? did you weld the backside of the root pass?
Reply:hahaha... gee i must be blind!Thanks.!-Clarke 130EN-Miller MaxStar 150STL-Miller Elite 29' Roadster
Reply:Heres the full pen. fillet that I said I would do.Side view of the joint.....tacked with 6011, the MIG tacks last night caused some troubleJoint again..1st pass...I think this is passes 4 and 5....And 6 and 7...on to next post to see the all important root....CharlesThunderbolt AC/DCRed Flames BWELincoln sp-135t
Reply:the root didn't come out as well as i hoped. the machine took a little dialing in before it went in good. take notice that the starts are very cold and theres a nice little gap. feathering the stops and tacks would have been beneficialcut in half...this is as far as I could bend it with a vice and wrenchdoes it pass the visual inspection??? CharlesThunderbolt AC/DCRed Flames BWELincoln sp-135t
Reply:Great Job!I´m wondering... how much time did you waited for doing so many passes with the duty cycle of your machine?My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:NICE!  So you can weld 3/8     With the prep you did, lots of surface area for the weld to hold on to.   I still prefer to burn that far in with .045 wire and a couple hundred amps.  Thanks for taking the time.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:David - the entire point of these posts was to show the readers of this forum that these small machines are capable of doing a little thicker material. Those people who said or didn't recommend doing thicker material with the small machines have the luxury and money of a larger machine. For those that DON'T have bigger AMP machines, the option is there to do these thicker material projects at home...with proper prep and beveling.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Microzone I understand and I was amazed at what I saw above.Going to do the output thing on monday with my SP100 and hopfully the shop next to me hefty 135.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Excellent demo of proper prep and multi-passing with a 110v machine to weld heavier material. I'm eagerly awaiting DavidR's welding amps results also.Craftsman 230a Buzz-box,  Lincoln 140T & 180T, Century K2789, PUROX W202 O/A14" cheapo chop saw that cuts straight and square!A toolbox of the cheapest Chinese tools money can buy"Real" tools all old reliable Husky/Craftsman/Proto stuff
Reply:Charles thank for sharing good job i new it could be donebecause i have with my sp135p both with solid and flux corebut now i got my tig up and running the 135 is a dust collectorChuckASME Pressure Vessel welder
Reply:The pictures give more credit to the operator than the machine.  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:This so true it hurts, I have done it, they will do a good job, it takes time, the down time between passes is what makes it so long to do,  these machines require a break as do most, a lot of people don't realize this, but the machine never forgets to cut off or shut down due to overheating
Reply:8 year old thread?Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2026-1-2 23:57 , Processed in 0.259198 second(s), 18 queries .
