Recently did this gate for a guy. Outer frames are 2x2x.120 wall, inner frame and cross brace 1x1.095. He supplied the hinges, prints, painted the panels, cut / fit the wood, and hung the frames. His design, and he provided the sealed ball bearing, adjustable hinges. The rectangle tube bolted to the posts were capped top and bottom to keep water out. Panels still need final adjustment. His buddy says he wants the same thing..so we'll see!-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:That looks nice man good job.now the rest of the fence needs a update now. It's kinda like just buffing half the hood on a car Last edited by motolife313; 02-18-2015 at 11:22 AM.
Reply:rabidc; that's a nice looking job. nice finish also. does the post sag or pull when the gate is extended?i.u.o.e. # 15queens, ny and sunny fla
Reply:Nice looking gates! I build a lot of gates - those are great hinges. It makes a huge difference being able to adjust the hinges a little, especially when you have a lock like that one.
Reply:Very Nice job ... I like building gates!!Located In SE OklahomaLincoln Mig 135Hobart Ironman 230 Mig5x10 CNC Table with DTHC & FTHypertherm PM65 on the tableMiller Bobcatwww.caneyagequipment.com
Reply:Originally Posted by motolife313That looks nice man good job.now the rest of the fence needs a update now. It's kinda like just buffing half the hood on a car
Reply:How are those hinges adjustable?I really have no idea what I am doing.Two Shop Cats (not Bobcats...real cats)Miller DialArc 250 AC/DCScratch-Start TIG SetupMIG 175Plasma CutterO/A
Reply:The brackets are slotted, so you get a max travel of 5/8 inward and outward. Just loosen the bolt / nut, adjust, and tighten.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Very nice looking gate....Want to try my hand at building one along that design, with the wood inserts, about 16' long. Have a wood fence down the side that I'm trying to match with the wood inserts. Thinking that two sections is the best design tied together with, haven't figured that out yet.Have also looked at swinging designs but that won't work well for me, so I was thinking a rolling one, but have not seen one up close so not sure about the track system design, but do have a nice flat area for it to roll away...Can start a new thread if need be, but your gate fits the basic design I'm going after, and I'm certainly not as skilled as you, wanted to ask questions using your gate as an example....Thanks,Andy Originally Posted by rabidchimpRecently did this gate for a guy. Outer frames are 2x2x.120 wall, inner frame and cross brace 1x1.095. He supplied the hinges, prints, painted the panels, cut / fit the wood, and hung the frames. His design, and he provided the sealed ball bearing, adjustable hinges. The rectangle tube bolted to the posts were capped top and bottom to keep water out. Panels still need final adjustment. His buddy says he wants the same thing..so we'll see!-Aaron
Reply:This was my first gate, but I'll help you if I can. I'm glad you like it.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Ok thanks,Obvious question: now that it is completed, what design changes would you make, if any?
Reply:I like it! Hinges Look good. I recently dealt with hinge making and didn't think of that design.
Reply:That rocks Aaron!! Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:That's a beautiful gate!
Reply:Originally Posted by USADOk thanks,Obvious question: now that it is completed, what design changes would you make, if any?
Reply:Mudman, Barn118, 7A749, glad you like it! Hopefully, dude's buddy will have me build a similar one for him!-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup |
