hey guys, I have a friend of mine in a situation and I'm looking to help him find someone qualified to do a welding job that he needs done. basically the problem is that the rear shock upper mounts to the frame rail with 2 studs and there is no easy way to replace these studs, no way to even do much from the top as it's a boxed rail section that is reinforced right in this area.what needs to be done is to grind both original studs flat, then fabricate a plate to cap the area with new studs... this setup can tolerate the additional thickness of this plate and ideally both sides would be done the same to keep it symmetrical. 2 options are either weld nuts to the plate or weld some grade 8 bolts as studsI'm not looking for charity work here, more than willing to pay what something like this should cost, only problem is finding someone who is A willing to do it and B, capable of doing it wellhere is a picture of the area in question and an idea of what needs to be done, it's pretty easy to access with the wheel off and I could probably get my friend to remove the interior trim ahead of time in prep for this welding... anyone who can do this or knows of a shop who can I'd really appreciate the contact for this, the guy is prepared to pay to have this done and I've told him to expect up to $300-$350 or so for the job done right, I'm hoping someone here can help or put me in touch with someone who can help, the last thing I want here is someone to make a butchery of this, really want to do it well the first time, thanks miller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:Year/make/model?Also, that's why I anti-seize almost anything I don't Loctite. Dry threads, unless factory-specified, are evil.
Reply:yeah man, me too, but these were original from 2003, probably never touched, and he kind of rounded out the nuts a bit trying to get them off and then gave up, so chances of salvaging the studs at this point are pretty slim... that's why I'm looking to cut them flush and weld a new plate, solve the problem once and for all. this picture is not from his, this picture is from one of mine but same car same setupvehicle is a 2003 infiniti FX45 and these are the rear upper mountsmiller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:where in the country is he? i will do it for free if he is near either of my offices in colorado or hawaii....
Reply:he is in Stafford Virginia, area code 22554... he is willing to travel a bit but to try and bring him all the way to me in NY would just be way too much hassle and really shouldn't be necissary for something this relatively straight foward, so I'm hoping to help him find something at least somewhat local to him. that's why I'm even offering what I think is pretty good $$ to do this in the hopes of finding someone who can and is willing to, really appreciate the offer though man, thank you for that Last edited by turbocad6; 05-08-2012 at 05:28 PM.miller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:ken's welding out of catlett, va. he'll fix you up ! google him!
Reply:hey lincweld thanks for the recommendation, I called and spoke to ken, then put my friend in touch with him to set it up, thanks, hope it works out well miller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc.... |
