Question on Dinse connectors/Tig Pedals
发表于 2021-8-31 22:06:41 | 显示全部楼层 |阅读模式
A friend has a multimaster 260 (Esab) welder where he has a bunch of spare accessories with it and I was wondering on compatability...He's got an extra ground/electrode holder, as well as a foot pedal and torch. Does anyone know if these are compatible with a Syncrowave? I checked the MM manual but didn't find anything on the sizes of these connectors. I figure its unlikely that miller and ESAB are compatible but thought I would ask before purchasing stuff from USAweld
Reply:The dinse connections are industry standard, a couple sizes are available.The pedal/trigger plug probably not most manufacturers have their own version
Reply:the potientometer in the pedal may be different, ohm it to see if it'll work. Potentiometers are cheap and you can change them out if you use some creative thinking.  may have to swap plug to machineLast edited by Michael ray; 05-13-2016 at 10:26 PM.Reason: forgot plug
GMT+8, 2026-1-2 23:57 , Processed in 0.100330 second(s), 18 queries .
