Wireless foot control screw up
发表于 2021-8-31 22:06:41 | 显示全部楼层 |阅读模式
I just got a wireless foot control for an older "analog" Syncrowave 250. The foot control doesn't work. Did I screw up?  Is this machine too old for this?  I guess I just thought a 14 pin connector was a 14 pin connector. Any ideas?
Reply:What are you using it on?  My understanding was that all Miller 14 pin works the same way.
Reply:Originally Posted by rlitmanWhat are you using it on?  My understanding was that all Miller 14 pin works the same way.
Reply:I did notice that the pins in the wireless receiver don't stick out as far as the old foot pedal cable. But still look like they should make contact in the welders connector.
Reply:I've been told they'll work on all 14 pin machines. Stupid question......but.....you did put batteries in, and the correct way?-DoogieMiller 350PMiller Trailblazer 325 EFI w/ Excel PowerLincoln LN25 suitcase welderXMT 304/22a feederMiller Syncrowave 350LXMiller EconotigHobart Handler 140(2) Uni-Hydro 42-14Hypertherm 65 plasmaWEBB Gap bed lathe
Reply:Originally Posted by derekpfeifferI've been told they'll work on all 14 pin machines. Stupid question......but.....you did put batteries in, and the correct way?
Reply:If you go to Millers web site,go to remote section you will find the appication area that shows what models they will work on,some also go by serial numbers.Not all will work just because its a 14 pin.If your not sure give miller a call they will help you out.
Reply:Originally Posted by SJCThe LED on the receiver doesn't come on.
Reply:The wireless controls are not compatible with all the 14 pin machines. There is a listing on Millers web site.Mike
Reply:The only list I saw was of current models that the pedal works on or doesn't.
Reply:According to the list it works with a syncrowave 250 dx but the syncrowave 250 model is not on the list.Mike
Reply:You had the shoebox pedal iirc older 250 they do not work on these machinesSent from my LG-H811 using TapatalkMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
GMT+8, 2026-1-3 00:12 , Processed in 0.100212 second(s), 18 queries .
