I recently purchased a Miller Dynasty DX 210 foir use in my home shop (garage). This is a hobby for me and I needed a adapter to use to hook it up to my Drier outlet. I used to rent a welder and they always gave me the adapter/extension cord. I searched online and really couldnt find one so I made one. I saw a couple of posts about it on here which was very helpful. I purchased NEMA 6-50r receptical and a NEMA 6-50P. I put the 6-50p on the welder power cord and put the 6-50 receptical on the new 6 ft drier electrical cord. Plugged it in and it workerd perfect. I am getting the garage wired for my welder soon but in the meantime this works. Hope this helps someone if they are doing the same.TEAM GUILTYMiller Dynasty 210 DX
Reply:Please re-work the 6-50p. The outer jacket of the cord needs to extend into the plug a little so if any stress is put on the cord it doesnt pull the connections apart.Eventual master of the obvious, practitioner of "stream of consciousness fabrication". P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
Reply:Will do. I just slapped it together to see if it worked. Tested voltage and hooked up the machine and it fired right up. Thank you.TEAM GUILTYMiller Dynasty 210 DX
Reply:Keep in mind dryers are 30 amp and most welder plugs are 50. But unless you are cranking the amps up you should be ok. Also newer dryers are a 4 prong plug. Kitchen range is a 50 amp, but different plug, again might be 3 or 4 prong. I once used vice grips to clamp bare wires to buss bars, might not have met code.
Reply:This is a 3 prong older house. Its temporary until I get the garage wired for it in the next month or so. I have a beand new welder and excited to use it. Wife has a couple of projects we are in the middle of. Bathroom bedroom etc... I need to weld a couple of things for my Quad. Lightbar andf skidplate.TEAM GUILTYMiller Dynasty 210 DX
Reply:Here is what it looks like in total. I still have to add the extension cord (15ft) but it works...... TEAM GUILTYMiller Dynasty 210 DX
Reply:Originally Posted by jsmithKeep in mind dryers are 30 amp and most welder plugs are 50. But unless you are cranking the amps up you should be ok. A
Reply:Originally Posted by SedanmanPlease re-work the 6-50p. The outer jacket of the cord needs to extend into the plug a little so if any stress is put on the cord it doesnt pull the connections apart.
Reply:Originally Posted by mikecwikYou think that looks ghetto........(seriously I agree with you on it though)http://www.hobartwelders.com/weldtal...s-a-bit-ghetto
Reply:Originally Posted by 7A749Great stuff Mike. You even look about exactly as I pictured you to I do stuff like that quite frequently only I have several adapter leads made up that run off one switch box. The leads with big jaw clips gets used most of the time. Connects to bare wires, terminal posts, plug prongs you name it
Reply:Ok, cleaned up and much better. Ready for use. I hope this helps somebody. I spliced the drier cable with the black power cable. Should do unti;l I get the electrician out here to wire me up a box.TEAM GUILTYMiller Dynasty 210 DX
Reply:Why didn't you just buy a dryer plug? Why the added gray pigtail.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1Why didn't you just buy a dryer plug? Why the added gray pigtail.
Reply:Originally Posted by Broccoli1Why didn't you just buy a dryer plug? Why the added gray pigtail. |
