Need stick welding advice!
发表于 2021-8-31 22:06:40 | 显示全部楼层 |阅读模式
Hey guys, just got in to stick welding and would like some advice. I'm not to sure what I'm doing wrong, so I've attached a photo of a practice weld to see what you guys think. Attached Images
Reply:Waaaaaay to cold!Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:+1 on the lack of amps.ChrisAuction Addict
Reply:Need to clean steel also
Reply:Heat it up. 10 to 20 more amps.
Reply:It helps when asking for help to give as many details as possible. Material thickness, rod size and type used, AC or DC+/DC-, amps used, machine used and so on. The more info you give, the better we can help..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Yeah sorry, I'm useing 2mm rods on a DC machine set to 40 or 45 amps.
Reply:Originally Posted by Tiny-TimYeah sorry, I'm useing 2mm rods on a DC machine set to 40 or 45 amps.
GMT+8, 2026-1-3 00:13 , Processed in 0.097680 second(s), 18 queries .
