Simple question tryin to be safe not sorry******
发表于 2021-8-31 22:06:39 | 显示全部楼层 |阅读模式
aliright, I have a sa250 diesel and it is wired for a remote when I bought it, all work done by a machine shop. the ac output of the machine was taped over and put back inside the machine, so there is no ac power plug in on the machine. it was chopped and put in an older sa200 frame to cut down on size and the shop didn't bother to cut holes for the ac plugs. all this was done before I bought the machine. When it was wired it was wired with only the regular three wire plug like on a sa200, not the 4 wire like on a 250/300. Would a sa200 remote work on the machine just not have ac output at the box?
GMT+8, 2026-1-2 23:57 , Processed in 0.099462 second(s), 18 queries .
