Convertin '47 short hood?
发表于 2021-8-31 22:06:35 | 显示全部楼层 |阅读模式
Would someone be able to explain to me what is needed to convert a 1947 f162  model #671 from hand crank to electric start.
Reply:As far as I have been able to determine code 671 has no provision to convert to electric start.  Maybe someone else knows better than I?Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:These are the only two threads I found with a quick search on the AWS Forum. I'm sure there are more if you can tease them out with the search function. Good luck.http://www.aws.org/cgi-bin/mwf/topic...ectric%20starthttp://www.aws.org/cgi-bin/mwf/topic...ectric%20startOnly when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:With all the research I have done I think the easiest and cheapest way to do the conversion is to fine a f162 that has electric start and swap the entire motors out.
GMT+8, 2026-1-3 01:21 , Processed in 0.069758 second(s), 18 queries .
