Dfferent Questions on Weldanpower
发表于 2021-8-31 22:06:35 | 显示全部楼层 |阅读模式
Hey dere;Couldn't figure how to add this pic, so the new thread. weldanpower Code 8928,Serial A1040360Still figuring out if I want to get a transfer switch, such as Relaince whic is made here, I am told. Or the use the shop 230 outlet , thing. Here's the latest questions;Can anyone tell me where to buy the 230 sideways plugs that this 230 plug takes off the welder?Annnd, where the heck can I pick up a bigger gas tank? I beleive that the original oval tank is 1-1/2 gallons. It is a fine tank, but not much run tiome when the lights go out. precciate all the good help! Attached Images
Reply:6-15 15amp 240v Plughttp://www.google.com/search?client=...UTF-8&oe=UTF-8Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:....but the problemo you have is that the Lincoln only provides 120v OR 240v from their respective receptacles- you don't have a 120v/240v receptacle on the machine so not good for providing power to the House since the 240v receptacle does not provide a neutral.It is not a plug and play set up.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2026-1-2 23:57 , Processed in 0.074449 second(s), 18 queries .
