Can anyone ID this welder?
发表于 2021-8-31 22:06:34 | 显示全部楼层 |阅读模式
This machine is in our farm shop. Can't identify the model, output polarity, amperage, etc. I remember first seeing it over 30 years ago and it was old then. It actually still works very well. It's shaped like a tombstone, has hand crank on top. The only markings still visible are on the oval plate attached to front of machine:HD408993220/440115/58H4002525 34006018I would appreciate any help. Attached ImagesLast edited by ranger140892; 07-25-2011 at 11:59 AM.
Reply:NEED PICS  so we can seeidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:attached photo to original post
Reply:kool  but more pics will realy help pics of any and all tags ,stickers, top sides  hard see much the red emblem looks  like  a peterbuilt goose eggidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:It's not a Lincoln afterall. It's a Hollup. I took the oval plate off and the back side has info on it. Can no longer read any of the specs but at least I confirmed it is an AC welder.Anyone know where I can get info on Hollup?
Reply:Please forgive me for this but...Take it to a bank, plunk it down on the counter, point your finger at it then say in a loud voice, "This is a Hollup!" Sorry... just couldn't resist. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:LMAO tooo funny  ok : ranger to do the detective work on this welder (0l' lady) we need as much info as you caN give your location ,if it has been there as long as you can recall..doyou can you ask where it came from  have you thought about opening it up some will have paper work glued inside sometime ( the ol day swho when where ?????idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:did a fast   GOOGLE and found some stuff on Hollup welders???  have you tried to google itidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:NCG  - Hollup we had 60 of them  worked great WW-2 vintage 500 amps AC single phase fan would burn out and we kept using , wish I had one now !!!   John
Reply:Rick V, you're killing me. How am I gonna outrun the security guards with a 400lb welder in my arms?Prop-Doc, I didn't see any paperwork inside. Meese's woulda used it for nests by now anyway. However I now know it came from a company in Vicksburg that made large commercial propane tanks. And yep, I've googled it.I blew the inside out. Shortened the ground lead to get rid of exposed copper. Bought new rods. Pre-positioned 3 fire extinguishers, posted a guy at the breaker box, and plugged it in. The thing welds like new. Reckon I'll be building some hog traps this week.
Reply:i have one like except it has a low and a highamp  for the leads i love it put a 300 amp dc converter on it and it welds better than i will ever be.
Reply:Jughead, mine also has high and low but none of the markings are visible. Could you photograph yours for me? I'm assuming mine is set up for highest amp range. Cranked to highest amps, mine burned right through a piece of 3/16" plate as soon as it arc'd. Cranked to lowest, I can just barely weld 1/8" angle iron without blowing out the edges.
GMT+8, 2026-1-2 23:57 , Processed in 0.073958 second(s), 18 queries .
