long router bit for aluminum?
发表于 2021-8-31 22:06:31 | 显示全部楼层 |阅读模式
I need to buy a straight cut router bit.  Cut width = 1/4". Cut length needs to be greater than 1.5".  Basically I am notching a gimbal in 1.5" aluminum tubing.  I can find longer bits for 3/8" diameter cuts, but not for 1/4" cuts.
Reply:Do you have a picture or sketch?
Reply:Look into end mills instead of router bits. Like shown herehttp://www.mcmaster.com/#end-mills/=lndikj  Personally I think that much stick out on such a small bit is asking for breakage which is probably why you won't find router bits that long.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:One thing is you may have to make multiple passes to do what you want to do. In that case, length of cutting surface won't matter as much as the overall length of the cutter. Simply reset your depth and make a 2nd, 3rd or however many passes it takes to get the job done..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:you might also  look at carbide rotozip bitsmiller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:Originally Posted by middleofnowhereI need to buy a straight cut router bit.  Cut width = 1/4". Cut length needs to be greater than 1.5".  Basically I am notching a gimbal in 1.5" aluminum tubing.  I can find longer bits for 3/8" diameter cuts, but not for 1/4" cuts.
Reply:+1 on the end mills and similar cutters.  Here is one at ENCO which seems to meet your needs (about $65 though)...http://www.use-enco.com/CGI/INLMKD?S...01=1&SICOUNT=1Now, if you can go up to a 1/2" router (the other standard router collet size), then you have plenty of options in 1/2" cutters...http://www.use-enco.com/CGI/INSRIT?P...PMAKA=337-5902I use a router all the time for aluminum and I've been looking for bits like this to expand my abilities.KevKevin / Machine_Punk from The Aerodrome Studio - Lincoln PowerMIG 210 MP - Meco N Midget w/custom welding station - Vintage Victor 100Current Projects: The Aerodrome Studio
Reply:Originally Posted by brucerif the part is square can you use a vise and just flip the part over, all you would need to do is use a stop on one end to locate the x axis.. if round, can you use a vise and use a small fixture to locate off the slot you have already cut on the first side? I have no idea what type of machine your using or what kind of tolerances your looking for..
GMT+8, 2026-1-3 00:12 , Processed in 0.097818 second(s), 18 queries .
