I am curious about the wiring in an inverter.At some point the unit must change the input frequency from 60HZ to an adjustable frequency. My first question is: Is that conversion done prior to the amperage amplification or after?2nd question....if the frequency is changed first, then could you add that into the circuit of a transformer based unit? The reason I ask is because I am interested in adjusting the frequency and can not figure out why it isn't a simple task. If it is done after the fact, then it should be even easier.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Delete!Last edited by joshuabardwell; 03-02-2013 at 01:49 AM.
Reply:Why would you reply with that?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11Why would you reply with that? |
