58' 100,00lb coal stand pipe
发表于 2021-8-31 22:06:26 | 显示全部楼层 |阅读模式
Got this job on Monday.  57'9"1/2 tall coal silo fill tube, 1" A36 shell 9'2" OD with 3/8" Hardox 400 liner estimated finish weight 100,000lb deadline is 1APR2015.  We had the shells rolled at another facility due to time and space restraints (they say they are working on a new tank shop for us but I'm not holding my breath) all are rolled perfectly and are within a 1/16 in diameter.  The only thing that has me ticked off is QC wants to use 307L stainless in spray transfer to attache the liner he says that's the best way but my shop super says that's bull s#!t and i have 138' of weld to make on the 3/8 Hardox liner.  Oh and a pic of the 90ton rolls their rent for me at a $1,000.00 a week.Last edited by colindstark; 02-07-2015 at 08:57 PM.
Reply:Looks like a big job!Millermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina
Reply:I don't understand why your company even bid this job.1. Why bid a job you don't have time to do?2. Why rent tools you need to do the job? Because if you are doing this job you will probably do more.3. Why are you, your shop super and QC even discussing the procedure AFTER bidding the job? 4. Why was the process not part of the quote?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11I don't understand why your company even bid this job.1. Why bid a job you don't have time to do?2. Why rent tools you need to do the job? Because if you are doing this job you will probably do more.3. Why are you, your shop super and QC even discussing the procedure AFTER bidding the job? 4. Why was the process not part of the quote?
Reply:Do you mean carbon steel electrodes? Maybe you can discuss it with the QC guy. I would bet there's a gas shielded flux core that would weld it but maybe there's a reason QC wants stainless, ie/ corrosion resistance, harder weld deposit, etc.. If the shell is 1" thick, why aren't the seams beveled? The whole thing looks like a good candidate for sub-arc welding.
Reply:That's a neat project using different grades of steel, the company that pays my mortgage makes Hardox and a36 granted a36 is a lot more common than branded wear plate. I don't get to see many end uses of our plate just shipping the stew out of it, I enjoy seeing what it becomes.Ranger 250 thick stuffHobart Handler 140 not thick stuffthe pane and oxy setup
Reply:Originally Posted by Welder DaveDo you mean carbon steel electrodes? Maybe you can discuss it with the QC guy. I would bet there's a gas shielded flux core that would weld it but maybe there's a reason QC wants stainless, ie/ corrosion resistance, harder weld deposit, etc.. If the shell is 1" thick, why aren't the seams beveled? The whole thing looks like a good candidate for sub-arc welding.
Reply:Here is all 6 shells fitted Attached Images
Reply:Started cutting out the windows today oxy-fule track torch on 1 inch A-36.
Reply:I bet the 666 is getting a workout on that job Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Originally Posted by 7A749I bet the 666 is getting a workout on that job
Reply:I figured it was the issue. Glad you got it workingExpert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:This thing had the OLD screw in buss fuses
Reply:Yeah, she's an oldie alright. Those slat louvered front panels are sixties, maybe older.Whatever the case, it's old Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Just cutting out some windowsAttachment 1059621
Reply:Well it's done with the windows it was over 100,000lb but finished weight was 90,500lbs
Reply:That's some big stuff man!!Expert Garage Hack....https://www.facebook.com/steven.webber.948
GMT+8, 2026-1-3 00:13 , Processed in 0.106597 second(s), 18 queries .
