CNC Plasma Table
发表于 2021-8-31 22:06:21 | 显示全部楼层 |阅读模式
This is our 3rd table to build. It is built very sturdy and performs very well. It utilizes many things found on high end system costing over 15K. We built this table to sell, it has a couple of hours of use on it.Pictures & Videos: https://picasaweb.google.com/1053800...79/April232012Our website: NorthridgeFab.comEmail: NorthridgeFab (at) gmail (dot) comPhone: 970.626.sixty ninetySpec's:Cut Area: 48x60Table Size: 55x65Gantry Parking area30mm linear bearing slide on X & Y axises15mm linear bearing slides on Z axisAdvanced Height Control w/Floating HeadTall clearance gantry for cutting SQ tubing, Channel, I-Beams, Etc.Dual side drive gantry6" deep water table.Curved slatsRack & Pinion drives3:1 reduction on X & Y axises via timing belts/pulleys5 Start Z axis acme screwAll motors are Hybrid 620oz steppers w/Gecko DrivesCandCNC Controls w/custom Mach3 ScreensDell DesktopSheetCAMMach3 (Already calibrated to table)The plasma cutter and torch are not included in the price. If your interested in them, contact us.We are located in western Colorado. Pickup is welcome or we can deliver the machine any where in the US for 1.25-1.65 per loaded mile depending on distance.8950.00 oboDynamic MetalworksMontrose, CODynMetalworks.com
Reply:Do you have pics?
Reply:there is a link in the post above for photos
Reply:Love it man.  Only concern is that it seems the water and sparks are landing on the electronics under the table.Millermatic 251Miller Bobcat 225Lincoln 135Victor Oxy/FuelOlder Thermal Dynamics 50 amp (paid $700 with 10 sets of consumables)
Reply:Originally Posted by MoroneysWeldingLove it man.  Only concern is that it seems the water and sparks are landing on the electronics under the table.
GMT+8, 2026-1-2 23:47 , Processed in 0.101641 second(s), 18 queries .
