Any welders have ac Frequency, balance controls in Sin, triangle wave?
发表于 2021-8-31 22:06:18 | 显示全部楼层 |阅读模式
Hi, I'm confused that if the balance setting is available in Sin, triangle wave.Any welders have ac Frequency, balance controls in Sin, triangle wave?
Reply:Originally Posted by Jeremy17Hi, I'm confused that if the balance setting is available in Sin, triangle wave.Any welders have ac Frequency, balance controls in Sin, triangle wave?
Reply:Curiosity...I know we are stuck with sine waves when we use transformer welders.And square waves are great for adjustable balance since the amplitude of 'on' is always the same.But what advantage are triangle, saw tooth or other wave shapes in welding?Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:Originally Posted by mike837goCuriosity...I know we are stuck with sine waves when we use transformer welders.And square waves are great for adjustable balance since the amplitude of 'on' is always the same.But what advantage are triangle, saw tooth or other wave shapes in welding?
Reply:I hear triangle is great for overhead or maybe Coke cans but can't say for certain as I don't have it........yetTorchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:http://www.weldingtipsandtricks.com/...interview.htmlEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Thank you all to answer my question!!!!Last edited by Jeremy17; 05-19-2016 at 04:40 AM.
Reply:Originally Posted by 'StangOk! First, you are not stuck with sine wave just because it is a transformer machine. The newer transformer machines are square wave. The advantages of the different wave shapes are puddle control, and heat input.  My Dynasty has the traditional sine wave, in addition to advanced square wave, soft square wave, and triangular wave. The triangular wave is probably mostly used on thin aluminum. I haven't used it, so I don't know how well it works.I do like the advanced square wave over the soft square wave. I think it gives me better penetration. Hope this helps.
GMT+8, 2026-1-3 01:20 , Processed in 0.105348 second(s), 18 queries .
