Tig welding aluminum from a Trailblazer with a hi-freq box
发表于 2021-8-31 22:06:17 | 显示全部楼层 |阅读模式
Does anyone have much experience with this?  How well does it work?  Do you prefer something else for tig welding aluminum in the field.Miller Bobcat 225AHP AlphaTig 200X
Reply:A lot of guys just use a spoolmatic 30a off thier trailblazer for aluminum in the field. Or a dynasty 200dx for thinner aluminum that requires a tig weld. If ur trailblazer is a ac dc model then i guess a hi freq box and tig setup would work just fine...i think at least. Someone else will chime in with some more infor hopefully, but what i just stated above is how most peolple do mobile aluminum workDynasty 200DX   (2014)Millermatic 211 (2015)Optrel 864   (2014)Smith Medium duty MBA 30510 (Xmas 2014)Tennsmith 16ga 4ft finger brake (2015)Trailblazer 325 EFI and excel Thermal dynamics Cutmaster 82Miller maxtron 450
Reply:Yep I run that set up.  I have a 302 ac/dc and a 251d with a pedal.  Turn the main dial all the way up and go to town. I have a 30a spoolgun as well but on thin stuff tig can't be beat or at least I think so.
GMT+8, 2026-1-3 01:47 , Processed in 0.073213 second(s), 18 queries .
