查看: 13|回复: 0
Dumb stainless question. Filler.
发表于 2021-8-31 22:06:17 | 显示全部楼层 |阅读模式
Can I use er70s-2 on stainless? It's for a side table so not really structural. Unfortunately for me (and WTF!) I live in an area that doesn't have a welding shop open on a Saturday.Big F**king HammerJumper cables & 2 marine batteriesJaws of life
Reply:It would work in a pinch, same way you use 308L on regular mild steel.  Not optimum, but it will mix with the base metal, somewhat. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Yes you could use it and it will rust.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Yep it will work
Reply:Use it with C-25 gas with your mig or Argon with your Tig.I do it all the time on stuff that no body insists do anything more than hold solid.
Reply:P.S.It is NOT a dumb question....And it most certainly is something you should just try yourself.
Reply:It is a Carbon Steel rod, it`s not designed for joining dissimilar metals like 308 or 309.But for something not structural ?Yeah, it will work, it will hold, and it will rust
Reply:Originally Posted by wornoutoldwelderUse it with C-25 gas with your mig
GMT+8, 2026-1-3 01:47 , Processed in 0.132072 second(s), 18 queries .
