61 magneto fires unless bolted to machine
发表于 2021-8-31 22:06:16 | 显示全部楼层 |阅读模式
I can spin the magneto by hand and get a half inch arc from a paperclip to the magneto body. When I bolt it to the machine I get nothing.  The kill switch lug on the side opens when turnover engine. Welder is 61 sa200 with fairbanks Morris fx4b mag. Any ideas?Sent from my SAMSUNG-SGH-I337 using Tapatalk
Reply:Internal short? on the shaft to the body? Have you open the bakelite and checked if you can see anything? Loose wire, bare spot  or anything like that.Klutch 220si mig , stick, and dc tigHobart 140 AHP ALPHA 200X 2016Lotos LTP5000DSmith O/P
Reply:He got it figured out tinker.  180* out.http://weldingweb.com/vbb/showthread.php...-mag&highlight=MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Wished people would not double post like that. But glad he figured it out. ThanksKlutch 220si mig , stick, and dc tigHobart 140 AHP ALPHA 200X 2016Lotos LTP5000DSmith O/P
Reply:Hear ya there.Human nature.  Ask three different people the same question - get the answer three times faster. Last edited by duaneb55; 05-21-2016 at 11:03 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:No. New to site asked in general then I found the Lincoln forum. Sent from my SAMSUNG-SGH-I337 using Tapatalk
GMT+8, 2026-1-3 01:20 , Processed in 0.111723 second(s), 18 queries .
