Lincwelder 225
发表于 2021-8-31 22:06:15 | 显示全部楼层 |阅读模式
I bought a lincwelder 225 a couple of weeks ago and i am trying to figure out if i have the charge rate switch hooked up correctly. Th man i bought it from put a key switch in the machine instead of a toggle i don't know it he hooked it up correctly or if i need to rewire it some pictures or wiring diagram would be greatly appreciated
Reply:These were posted by another member/Lincwelder owner, doubled,  awhile back that show the 2-position charge switch arrangement.  Some units had a 3-position.M10148.pdfS12953.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thank for the post i will try and decode these if any one has some pictures that would be great thanks
Reply:Do an Advanced Search of keyword Lincwelder 225 for several threads with photos.  Not sure how much more helpful they'll be than the wiring schematics should be.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-3 03:07 , Processed in 0.101484 second(s), 18 queries .
