R-57 idler?
发表于 2021-8-31 22:06:14 | 显示全部楼层 |阅读模式
Will someone explain the R-57 idler operation to me. Should it be pinned in the last hole or the middle hole?
Reply:These should help.http://www.lincolnelectric.com/asset...oln3/IM179.pdfhttp://www.lincolnelectric.com/asset...n3/IM179G1.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks
Reply:I forgot to mention that the R-57 was used on several different welders so the appropriate unit manual would offer specifics for any specific machine.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-3 01:31 , Processed in 0.231426 second(s), 18 queries .
