Barn Find gas welder
发表于 2021-8-31 22:06:14 | 显示全部楼层 |阅读模式
I picked this up off craigs list yesterday for $500,(no leads)it doesn't have a meter on it but appears to have very low hours.The sheet metal and face is in near perfect condition,from the serial# it dates back to 1987. Whats the history on these? were they reliable units? It seems to weld real nice. Also what is the CC and VV mode about?.a link to more photos  https://picasaweb.google.com/jimcaf12/LincolnGasWelder....thanks jim Attached ImagesEsab Multimaster 260Esab Caddy160IEsab 161 STLESAB powercut 650Esab 220i tigLincoln Precision Tig 225Lincoln IdealArc 250INE SKYLINE 1500Klutch 140iMEASURE TWICE IS FOR MORONS
Reply:This was a good find. I have welded with these, never owned one. They're good, dependable machines, if taken proper care of. There have been several rebuilds of similar machines on this forum and if you can keep this thread out front where it'll be seen, some one with more experience with them will weigh in. The mods like keeping the number of threads to almost none, so bump it up until some one answers your questions.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Originally Posted by jim cafarelliI Also what is the CC and VV mode about?.
Reply:That has a 2 cyl Onan engine, if it is running well , take care of it and it will continue for a long time. Let that motor over rev or run out of oil and you are looking at $1600 to rebuild it, Onans have become very expensive for parts. Great machine, Wire feeders will run from it but wire type and size are limited. Good stick welder for 7018  1/8 . I have had several. Keep that fuel tank clean, there getting hard to find, I found 1 used at a weder repair facility but he wanted $300 for it. No thanks, now have a plastic boat tank."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Thanks for the post guys,,good info!! It runs and welds great.It is heavy!!,,I been busy cleaning up the welder and reworking a jet ski trailer I picked up a couple of years ago should make it easier to maneuver it around then on a dolly,thanks again jimEsab Multimaster 260Esab Caddy160IEsab 161 STLESAB powercut 650Esab 220i tigLincoln Precision Tig 225Lincoln IdealArc 250INE SKYLINE 1500Klutch 140iMEASURE TWICE IS FOR MORONS
Reply:Good find had one just like it without the CV optionThat look like a B7800 kubota like mine it pick's up my Miller TB 302 Air Pak without a problem but that little welder isn't light by any meansBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Wow what a nice find for 500 bucks!Drink a Guinness Draught....Millermatic 140Do you still rememberDecember's foggy freeze --when the ice thatclings on to your beard isscreaming agony.
Reply:I think they weigh in at around 510 Lbs.  500 anyway ."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Yeah thats my B7800, the loader has  no problem lifting it,but my front tires looked pretty squished and I could really feel my power steering working hard,that tractor is hands down the best tool Iv ever bought. Its like having four big grunts around to help me lift and move stuff, Kolot I agree about 500lbs,I think on average jet ski,s are 600lbs and up so I think that little trailer is going to work out well,,,jimEsab Multimaster 260Esab Caddy160IEsab 161 STLESAB powercut 650Esab 220i tigLincoln Precision Tig 225Lincoln IdealArc 250INE SKYLINE 1500Klutch 140iMEASURE TWICE IS FOR MORONS
Reply:That is not an Onan engine. It is a Kohler Magnum 18-20 hp engine. You can still easily get parts for this one. The Onans are a bit more difficult to find parts for. I own two of these Kohler engines. One is on a commercial lawn mower and the other one I picked up last year to use as a spare for the mower.  The only significant problem that I've ever had with the one on the mower was the internal governor, which broke at about 3200 hours and required a complete engine tear down to fix. Nothing in the motor appeared to have any significant wear, so a new design governor, gasket set, and about 15 hours labor fixed it (Kohler must have realized the old governor design was inferior). The mower engine now has over 4500 hours on it. In your welder this engine should last you a very long time. CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:[QUOTE=CharleyL;538953]That is not an Onan engine. It is a Kohler Magnum 18-20 hp engine. You can still easily get parts for this one. The Onans are a bit more difficult to find parts for. I own two of these Kohler engines. One is on a commercial lawn mower and the other one I picked up last year to use as a spare for the mower.  The only significant problem that I've ever had with the one on the mower was the internal governor, which broke at about 3200 hours and required a complete engine tear down to fix. Nothing in the motor appeared to have any significant wear, so a new design governor, gasket set, and about 15 hours labor fixed it (Kohler must have realized the old governor design was inferior). The mower engine now has over 4500 hours on it. In your welder this engine should last you a very long time. Hi Charley thanks for posting but its a Onan 16hp on this one jim Attached ImagesEsab Multimaster 260Esab Caddy160IEsab 161 STLESAB powercut 650Esab 220i tigLincoln Precision Tig 225Lincoln IdealArc 250INE SKYLINE 1500Klutch 140iMEASURE TWICE IS FOR MORONS
Reply:Somebody put that tag on there................Okay, even if it was an Onan employee. jim cafarelli - You sure scored a proud piece. That baby is museum quality!Last edited by denrep; 08-03-2011 at 02:58 PM.
Reply:Yeah, Onan put it on there, I do know these engines, don't ask why? like I said, take care of it it will be nice, do not take care of it it will bite you in the wallet.   In this particular time frame only 2 motors available, 16 hp Onan, usually with CV and the 16 HP Briggs single cylinder rarely but optional CV I have 2 Briggs and 1 Onan.  Both are good little machines especially for 5 bills.Last edited by kolot; 08-15-2011 at 12:01 AM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2026-1-3 01:22 , Processed in 0.099439 second(s), 18 queries .
