What a Deal
发表于 2021-8-31 22:06:13 | 显示全部楼层 |阅读模式
Look what i found for $500  Found it behind an old lumber yard, after i got it started and welded with it the old guy said he needed at least 500 for it I almost fell over. The carb. leaks a little and the old R-57 idler does not work, but i am waiting on the idler upgrade kit and hose kits to get here to fix it up some. I replaced the battery and most of the wire on the starter, kill switch, and amp meter ect.  all the wiring from the generator to the rheostats seems fine so far.
Reply:Must have forgotten the pictures. Attached Images
Reply:Originally Posted by moneynotfunnyLook what i found for $500
Reply:I know it looks rough, but it runs and welds smooth. It is a late '69 model.
Reply:Good find. Cant beat that
Reply:Nice machine,but get rid of that ugly muffler. Love the way those old 200s sound with straight pipe and flapper
Reply:The muffler is gone.
Reply:Congrats! Keep in mind that the 110 outlet is DC as well. I've seen lots of guys burn up AC tools trying to run them on the DC.
Reply:Yea about that, the outlet does not work. It has a 15amp fuse, the fuse is good but  the outlet does not work. Attached Images
Reply:Do I see mud in the plug ?  If from mud dauber wasps you may have more under the hood, in air cleaner and who knows where else they can make a mess.
Reply:Yea that is  mud. I dug some out of the radiator drain also. I cleaned out the air filter nothing in it. I think all I have to do is change out the plug but not sure where to find one like this.
Reply:The plug on yours is not the type that came on it.  They had just single receptacle round type fit in one hole and didn't have a fuse sticking out like that.  http://www.billswelderrepair.com/schematics.html
Reply:What do you guys think I should repace it with?
Reply:Single receptacle plug,  bottom of this link page.  One plug is all you can run and pin the idler with running power tools with DC rating no variable speed or AC only power tools will fry them.  If you want to run other tools put on a bigger alternator on and a inverter. You said a update kit is coming though but still can only run DC tools.http://www.billswelderrepair.com/SA200misc.htmlElectronic Idler: IM-277-A  Gas engine adjustment, timing, carburetor, governor. idler & trouble shooting charts pages 10 & 11.http://www.lincolnelectric.com/Asset...OLN3/IM277.pdf
Reply:Thanks for the information, you guys know your stuff. The idler upgrade kit, choke cable and hoses should be in tomorrow. When I install the new electric idler will this also cause the machine to go to high idle when using power tools?
Reply:Ok replaced recepticle with this one. More like the original 115 single. I still can't get any power from it, I pin it in high idle put nothing. I have amprage through all the ranges but nothing at the plug. I got the new idler from Hybriweld today but if I do not have power to the plug will this cause the new idle not to work. Attached Images
Reply:Check the unit wiring against the 6th schematic down here http://www.billswelderrepair.com/SA200schematics.html titled " LINCOLN SA-200 WITH R-57 IDLER".MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Ok, got the aux. plug working . Thanks for the wiring diagram. I also took the r57 idler apart and got it working too. I am still going to replace it with the new electronic idler I got from Hybriweld. If I can figure out where the reed assembly goes, any ideas?
GMT+8, 2026-1-3 03:07 , Processed in 0.102273 second(s), 18 queries .
