Hypertherm Powermax 30 questions
发表于 2021-8-31 22:06:10 | 显示全部楼层 |阅读模式
i am fairly new to the world of plasma cutters.  i recently picked up a used Hypertherm powermax 30 and need to know if a should use additional filter for moisture?i only use this for hobby use and didnt want to spend hundreds on a fancy filter system if its not neccessary.any help would be great!!thanks!!
Reply:Any moisture is too much, there are many threads on here on this subject.
Reply:If it is for hobby use and you drain your compressor tank every time it is used...there is no need whatsoever for additional filtration. Many users over filter their units at a rather high cost.....and more filters in many cases restrict the flow.Jim Colt  Hypertherm Originally Posted by arkansasammyi am fairly new to the world of plasma cutters.  i recently picked up a used Hypertherm powermax 30 and need to know if a should use additional filter for moisture?i only use this for hobby use and didnt want to spend hundreds on a fancy filter system if its not neccessary.any help would be great!!thanks!!
GMT+8, 2026-1-3 03:07 , Processed in 0.098485 second(s), 18 queries .
