Parting tool coolant guide
发表于 2021-8-31 22:06:10 | 显示全部楼层 |阅读模式
I part a lot of 316 stainless. I've never been real pleased with the insert life. It's not terrible but less than ideal. To give you an idea... I run this operation with the parting tool reversed because it's easier to check and change the insert.  I've been using a small coolant line to blow coolant into the part but invariably chips move it from time to time no matter how tight I make it. One time I lost the coolant entirely and ate the entire insert and blade which is never good. So I dreamed up a solution that really lays down the flood and is chip proof. It has a LOT more flow. Made from a scrap of 1/2" aluminum and a short piece of stainless tubing. I started by drilling all the holes and cross drilling the part. I then drilled a 40 degree for the tube hole with a center cutting end mill. I didn't originally plan for a tube but after testing with just the hole it was obvious something was needed to smooth the flow. I didn't get a photo of the tube but it was notched to allow full flow from one side. The short tube was pressed in and retained by the set screw/plug. Didn't take long to make but what a difference. I only have a few parts on it so I don't know how it will help the numbers but I'm hoping to an improvement. Attached ImagesLast edited by forhire; 03-07-2013 at 12:19 AM.
Reply:That looks good Nice jobBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:That was a great idea! When you had it, you should have looked in the mirror for a light bulb lit up over your head  When it is perfected, I think Ebay will be your next stop.  Thanks for sharing your idea.TxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:Originally Posted by killdozerd11That looks good Nice job
GMT+8, 2026-1-3 01:21 , Processed in 0.133338 second(s), 18 queries .
