Hi-freq lincoln Tig box on a weldanpower 225
发表于 2021-8-31 22:06:08 | 显示全部楼层 |阅读模式
I purchased a lincoln weld and power 225 machine this weekend and need some info/advice on what i need to do to get the high frequency box going.  So from what i am getting off the web i will not be able to use a foot pedal to control the arc.  Is this correct?   If i cant use a pedal that's fine but how do i wire the start switch into the five pin connector.  Does anyone have a suggestion on tig torches (i will be using air cooled setup).  I would like to use a foot pedal so if anyone knows some tricks please let me know.  Thanks, Matt
Reply:A phone call to Lincoln tech support may be worth your while.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Does the Weldanpower have AC?
Reply:Originally Posted by snoeproeA phone call to Lincoln tech support may be worth your while.
Reply:Yes it has AC.  I just got done printing the manuals on the machine and the hi-freq box.  That explained a lot.  I also ordered a contactor for my spool gun.  Next is a tig torch.  There are so many torches in a wide price range.
GMT+8, 2026-1-3 03:06 , Processed in 0.097387 second(s), 18 queries .
