Question for any weld techs or weld testers familian in xray
发表于 2021-8-31 22:06:07 | 显示全部楼层 |阅读模式
I've been pipefitting and boilermaking for 12 years.I just started a job that I had to take a 6g 2 inch test.  The contractor was going on ASME B 31.1 specs.This spec has to do with boiler procedures.but the tester and contractor wanted 6010 root.  Which ad a pipefitter I'm well familiar with and have passed 100's of xray level 3 tests.  But this contractor has hired a new testing company and within 2 weeks I have busted 2 tests with porosity which I've NEVER had a problem with.one question is if I'm (under B31.1 should be using boiler procedures for this, which is stated as tig root and stick out)Is there a different percentage of allowance on slag...porosity ect on a 6010 root as opposed to a tig root?Last edited by millpiondapiary; 03-18-2015 at 08:13 PM.
Reply:I think ASME specs say you're allowed a maximum 1/8" flaw regardless but some inspectors want no flaws. 6010 root and 7018 fill and cap is common. You don't mention where the porosity is?
Reply:No defects allowed xrays dont lie weld better or go home.
Reply:Originally Posted by PavinsteelmanNo defects allowed xrays dont lie weld better or go home.
GMT+8, 2026-1-3 01:22 , Processed in 0.072574 second(s), 18 queries .
