Had to bite the bullet
发表于 2021-8-31 22:06:05 | 显示全部楼层 |阅读模式
So it's that time of year, prom. I'm currently a junior and had to think of my "promposal"(can't believe I just called it that...ah jeez) well I'm not exactly a romantic so this is what I came up with. Big ole chunk of stainless I found and  1/8 6013Not perfect but it got the point across
Reply:What's PR.M?
Reply:Originally Posted by BistineauWhat's PR.M?
Reply:Originally Posted by dpaschyou know them youngins arent good with the spelling, always half assing words
Reply:Lincoln stick welder doesn't have the spell check stinger. Shoulda used the Miller lol
Reply:Also I had already muffed the other side so I was trying to be careful fitting letters in there. As you can see just kinda barely squeezed in that m
Reply:So did she say yes?ECAVE Still learnin'Lincoln AC225Lincoln 135SPHF ChopsawVictor O/ANumerous other items
Reply:Originally Posted by b00mhowerAlso I had already muffed the other side so I was trying to be careful fitting letters in there. As you can see just kinda barely squeezed in that m
Reply:Originally Posted by ECAVESo did she say yes?
Reply:Originally Posted by MinnesotaDave
Reply:Originally Posted by BistineauLooks like there was room in there for the O, between the R & M though. I guess you can't weld in a circle, so that will prevent you from welding on pipe, until you learn how to weld in the round.
GMT+8, 2026-1-3 01:55 , Processed in 0.212781 second(s), 18 queries .
