Weldcraft 25' WP-9 air cooled TIG torch with torch mounted remote-$165
发表于 2021-8-31 22:06:01 | 显示全部楼层 |阅读模式
Weldcraft 125 ampWP-9 TIG torch with 25 foot cable and leather sleeve. Remote torch mounted variable amp switch. New, never used. I bought a Lincoln TIG welder at an auction and found out too late it was bad after I had spent the money and outfitted it with cables, regulator and TIG torch.I can't use it. My loss is your gain. This torch, switch and leather sleeve and DIN connector would cost around $300. The remote switch is 15' long so10' of the TIG cable is wrapped and tied off. You can splice into the remote switch and lengthen it by soldering another 10' of control cable. Not a big deal if you know how to solder (and what welder doesn't know how to solder?)Thanks,Tony Attached Images
GMT+8, 2026-1-3 01:39 , Processed in 0.072768 second(s), 18 queries .
