Odd question
发表于 2021-8-31 22:05:58 | 显示全部楼层 |阅读模式
I'm a rig welder living in PA and have been thinking a lot about heading up to Canada to work. I'm curious as to what type of red tape I need to go thru to be eligible. Has anyone ever done this and if so what we're the requirements and/or complications? Thanks yall.
Reply:Originally Posted by adajroshoI'm a rig welder living in PA and have been thinking a lot about heading up to Canada to work. I'm curious as to what type of red tape I need to go thru to be eligible. Has anyone ever done this and if so what we're the requirements and/or complications? Thanks yall.
Reply:you may want to avoid ft mcmurray when you get there.i.u.o.e. # 15queens, ny and sunny fla
Reply:Food is awesome.
Reply:Thanks for the help tigmonster
Reply:Originally Posted by adajroshoThanks for the help tigmonster
Reply:Ever get over to the Rigwelder forum to ask?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Ft McMurray is where the money is. I've stayed in quite a few of the ft Mac oil sands construction camps. Most of the camps are decent but there are still a few bad ones in operation (old camps). There's nothing wrong with the food, the food is good in most ft Mac camps. Otherwise they wouldn't be able to get workers there. There was a massive forest fire in ft Mac area around the fist of May, it burned 25% of the city and the adjacent oil sands sites are still shut down as is all the construction projects. Things should be ramping back up by the beginning of June. I'm a Ft Mac worker myself. To weld in Alberta you will need a work visa and a Canadian social insurance number so you can pay the Feds income tax. You will also need a clean criminal record check including no DWI's. You will also require a journeyman certificate in the welding trade. Then you will require your structural or pressure welding tickets depending on what  field you will be welding in. That's the bare minimum. Most sites/companies will want you to pass a drug and alcohol test also. In Alberta they don't keep you around if you have too many repairs with your welds. Every weld must be good or they just lay you off and send you home.Last edited by snoeproe; 05-26-2016 at 09:13 PM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:[QUOTE=snoeproe;7288151] To weld in Alberta you will need a work visa and a Canadian social insurance number so you can pay the Feds income tax. You will also need a clean criminal record check including no DWI's. You will also require a journeyman certificate in the welding trade. Then you will require your structural or pressure welding tickets depending on what  field you will be welding in. That's the bare minimum. Most sites/companies will want you to pass a drug and alcohol test also. And you'll need all of that BEFORE you come into the country. I wouldn't be to sure of anything in the Fort Mac area starting up in the near future, Suncor layed off over 1000 workers last week, I have a buddy that worked there, doesn't expect to be back this year.
Reply:There's plenty of work still happening in Ft Mac. Suncor has 3 different sites in the ft Mac area. People are still buying gasoline.Obviously locals come before TFW's when it comes to work.Last edited by snoeproe; 05-26-2016 at 10:30 PM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2026-1-3 01:53 , Processed in 0.112913 second(s), 18 queries .
