Parts/service for a Meco torch
发表于 2021-8-31 22:05:58 | 显示全部楼层 |阅读模式
I  am not certain where to  post my thread, so I am starting here, hoping this is the correct area on this forum for it.I have my deceased father's acetylene torch, it is a MECO,  WeldMaster.I am wondering if :1) Meco is still in business and servicing these torches? 2) Where and how to get in touch with them?3) and are parts, seals, etc., available for it?4) will tips / accessories, from other torch manufacturers attach to this torch?    which mfgs?I think it needs servicing only because:1)  where the oxygen / cutting tip attaches to the body the tip is sloppy and spins and i can't tighten the nut to the body any tighter. 2)  where the oxygen lever pivots on the torch, there is  a great amount of slop / play.Last edited by Flywelder; 05-26-2016 at 11:55 PM.Reason: To add more info
Reply:MECO (Modern Engineering Company) was made in St Louis, Mo for many years. I have one of those blue anodized handle weld masters myself along with the big type O regulators. I'm sure your local welding supply can send it off for rebuild or you can contact a rebuilder directly. Tips are available for themSteveLincoln SA200 (1966 Redface)Lincoln IdealArc 250Steve1990 Miller Dialarc 2501993 Miller Maxstar 140 STR2015 Lincoln MP2101966 Lincoln SA200 Redface
Reply:i see tm technologies sells the meco torch. could be they have parts/attachments or service them as well?i.u.o.e. # 15queens, ny and sunny fla
Reply:I had a good experience sending a cutting attachment and torch handle to this company:http://www.regulatortorchrepair.comI think the company owner is a member here and he may respond to your post. When he received my torch he called to discuss the repair job, so you could tell him your concern about the connecting nut, and you could likely ask if he has a favorite source for tips. I had a great experience with the firm: personalized service, excellent repair/rebuild, and quick shipping.
Reply:MECO was acquired by Victor around 1999. Victor discontinued most of the torches."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2026-1-3 01:49 , Processed in 0.080558 second(s), 18 queries .
