Lincoln SA 200 Settings!! HELP!!!!
发表于 2021-8-31 22:05:55 | 显示全部楼层 |阅读模式
How should I set my 1964 Lincoln SA 200 when welding a SCH 80 Pipe, at a 45 degree angle with a 6010 P5 Plus electrode.
Reply:Uphill or downhill? Second gear (120-90) & 60 amps is a good starting place. 55 to 65 amps depending on your machine. If you're going uphill increase your amps. This is for 1/8" rod. 5/32" will be third gear (190-120) same amps.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:If you had a Cable remote, you could copy my settings. But as we all know, everybody welds differently, and every machine welds differently. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Wow, thats a pretty fancy looking box you got there CEP, I 'd bet whatever the cord leads to looks nice to.     When using 6010, I like to stay in the lowest gear I can, and keeping fine adjust on high end.     Brcause a little overlamp in amperage between gears can be made by using fine adj.      By doing it that way, you lessen the chaces of popout, and can hold a longer arc.    Thats good humor Gizard, I never thought about my sa 200 being a 5- speed.
Reply:Oh it'll do, not bad for a $200.00 machine.  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Let's get a better look at that Shorty next door!"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:OK, and the other one. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Looks like hes got his own Lincoln Museum over there.
GMT+8, 2026-1-3 01:53 , Processed in 0.106608 second(s), 18 queries .
