Dust Boot Question?? Help!!!
发表于 2021-8-31 22:05:54 | 显示全部楼层 |阅读模式
Does the dust boot for a Solenoid Linkage on an SA 200 help to idle down the machine? Or is it just simply to keep dust out of the solenoid?
Reply:Should be just a dust seal. Springs pull one direction and the solenoid pulls the other.Adjustable stops to set proper operation. Solenoid can be tested with battery voltage.
GMT+8, 2026-1-3 01:55 , Processed in 0.113601 second(s), 18 queries .
