need throlle solenoid for miller bluestar 2e
发表于 2021-8-31 22:05:52 | 显示全部楼层 |阅读模式
Looking for a solenoid for  my miller bluestar 2e.does anyone know of a place that sales these parts or has any used ones?   Thanks
Reply:I THINK this is it. Are you sitting down? http://miller4less.com/advanced_sear...x=0&search.y=0Is it electrical or mechanical? My was mechanical because the boot was missing. Some Aerokroil and patience loosened it. I removed the core and cleaned/lubed the core and coil bore. It was fine after that, but I keept it on my check list.Last edited by millrat; 03-18-2013 at 12:45 AM.Reason: ommision
Reply:I think its the problem everything seems to be there it just doesnt pyll the pin when u apply 12v to it. Thanks
Reply:Ok so i tested the two small black wires that connect to the throttle solenoid and im getting just over 12 volts , so my problem must be solenoid.
Reply:Originally Posted by millratI THINK this is it. Are you sitting down? http://miller4less.com/advanced_sear...x=0&search.y=0
Reply:Yes sir i checked for resistance and i got nothing.  So weldersales carry used miller parts also?
GMT+8, 2026-1-3 01:37 , Processed in 0.101667 second(s), 18 queries .
