Flux core picture
发表于 2021-8-31 22:05:51 | 显示全部楼层 |阅读模式
Flux core duel shield vertical practice on 1/2" plate and a bend test on another one I did. Going to take a test at work  in two weeks when the training class is over. All of the bend tests so far have been clean, the test is vertical, horizontal and overhead on one inch plate "v" groove with a backer.  Anybody have advice on things to do and not to do. Attached Images
Reply:Be sure to include a stop and restart in the root passes. When you cut it up into coupons for bending, bend it against your stop/restarts.1" plate? If that's the case, you its best to cut 3/8" wide coupons out of it and side bend them.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2026-1-3 01:31 , Processed in 0.108370 second(s), 18 queries .
